Help required locating stock!
Post  rufuskins on Mon 30 Sep 2013, 2:50 pm
UKTS Download 30087 contains a series of LMS Named Train consists. Included are consists with GWR 57ft Toplight coaches from the Trainset folder GW57ftToplights; e.g.
GW57ftToplights\gw_TK_2569.wag was missing from your Trainset (Referred by c:\1MSTS\Trains\Consists\BradfordF_1000SO_Leeds.con)
GW57ftToplights\gw_TK_2571.wag was missing from your Trainset (Referred by c:\1MSTS\Trains\Consists\BradfordF_1000SO_Leeds.con)
However the only 57 ft Toplight coaches that I can find refer to wagons defined by their Diagram number; i.e. UKTS 23680.
Can anyone help me, even if it shows me to be "as thick as two short planks"?
Re: Help required locating stock!
Post  35005CP on Mon 30 Sep 2013, 4:23 pm
Have you tried UKTS File ID 18512?
Post  rufuskins on Mon 30 Sep 2013, 6:19 pm
Yes; 18512 is an earlier version of 23680, but thanks for the reply.
I've just sent an email to Darwin for his help as 30087 is one of his downloads.
Post  35005CP on Mon 30 Sep 2013, 8:01 pm
I haven't downloaded File ID 30087, but is there a readme in the file that you can check against possible missing file downloads?
The File ID points to other coaches, so that might help?
Post  slipperman12 on Mon 30 Sep 2013, 8:13 pm
Hi Gentlemen,
I've looked through all the GW coaches and can't find any with the names quoted.
As the folder name is GW57ftToplights, I think it's safe to assume that they were/are from Frank Sandwell. Maybe from his version 1 pack, which is no longer available?
Post  35005CP on Mon 30 Sep 2013, 8:27 pm
Hi Ged, Alec,
If the files are no longer available, maybe you can copy some of the other .wag files and create the missing name files? What is it you are trying to do Alec?
Post  rufuskins on Mon 30 Sep 2013, 8:37 pm
I have been tidying up some downloads, and running them through Route Riter and this threw up this mismatch in several of the consists listed in 30087. I was looking to see how they might be used in an activity.
Obviously I will need to match the GWR coach number with the GWR diagram number and substitute as necessary, unless Darwin can advise me otherwise.
